have some coolant on plugs..idles real high and hesitates when i give it gas...would all these symptoms be a head gasket or somethin else???thx foe any help/
Check for a crack in your intake manifold. If you still have the plastic crossover, that may be the problem. Check your oil as well to make sure you don`t have coolant mixing with it.
i did the pi swap here are my mods
THE CAR HAS ALL THE BOLT ON'S
ALL FORGE INTERNALS, LEVEL 10 BLOCK
PORTED INTAKE, HEADS
VORTECH SUPERCHARGER, 2.87 IN. PULLY
75 MM THROTTLE BODY AND PLENUM
LONG TUBES,H NO CATS, MAC PRO DUMPS
FIDANZA FLYWHEEL,KING COBRA KEVLAR CLUCH
TREMEC 3550 TRANSMISSION, ALUM. DRIVE SHAFT
3.73'S WITH DETROIT DIFF AND MOSER 31 SPLINE AXLES
SNOW PERFORMANCE METH/WATER INJECTION KIT.
THATS ALL I CAN THINK OF
I have oil in my coolant. I also have oil leaking all over my spark plugs and coil packs causing the car to hessitate. I'm guessing it's my head gasket too.
No it's N/A and no nitrous. Yeah the RPMs hang then drop. I have to keep taking out my coil packs and plugs and drying them off til I get the money to get head gaskets done.
