tb/plenum question
Old Nov 11, 2006 | 02:14 PM
mustangj23's Avatar
mustangj23
Default tb/plenum question
Will a Accufab 75mm tb/plenum fit on fine with the stock airbox thing (sorry dont know exact name) or do i need to purchase a CAI.
If it works fine, would there even be a reason of purchasing a CAI over just the removedairsilencer+knfilter
I have an 04 gt coupe if you need to know that
Thanks in advance for the help
Old Nov 11, 2006 | 02:25 PM
JJ03MustangGT's Avatar
JJ03MustangGT
Default RE: tb/plenum question
yes it will work but its a bitch gettin it on, not to mention i got my 75 accufab combo then my jlt, and wow i noticed the tb and pl but even more with the cai. its not always about how much power you get, sometimes makin your engine work easier equals power
Old Nov 11, 2006 | 02:53 PM
Kikojiro's Avatar
Kikojiro
Yes a 75 mm TB / Plenum combo will work, but why did you chose a 75mm TB? Are you going to supercharge, or at least upgrade to a cold air intake and a PI improved manifold, you are putting two hi-Performance products on what sounds to be a relitively stock setup. But again yes it should work but wont have the results I think you are looking for.
Old Nov 11, 2006 | 04:31 PM
Mark99GT's Avatar
Mark99GT
ORIGINAL: Kikojiro
uhh, its an 04 , it has the PI heads and manifold. Yes it will fit and the 75mm is a good choice. I have the same combo on mine with the stock intake. The only thing I had to do was cut the rubber tabs on the intake hose (dont know what else to call them) so the rubber would stretch further inside the clamp. Youll see what I mean when you do it. If you're not delusional you'll get exactly the results you are looking for.
Old Nov 11, 2006 | 05:19 PM
mustangj23's Avatar
mustangj23
thanks for the help
Dokilar
15
Oct 16, 2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
treesloth
Sep 28, 2015 07:03 AM
