longblock v. shortblock
Old Nov 12, 2006 | 08:05 PM
handyandy's Avatar
handyandy
Default longblock v. shortblock
What is the difference? What do they mean? Just trying to learn more about engines.
Old Nov 12, 2006 | 08:08 PM
Kadence's Avatar
Kadence
Default RE: longblock v. shortblock
easy way is a short block does not come with heads and intake and all that stuff whereas a longblock is a complete motor.
Old Nov 12, 2006 | 08:11 PM
ponysnake99's Avatar
ponysnake99
dont get it confused with a small block and a big block...thats another story though, had that problem when i first started
Old Nov 12, 2006 | 08:13 PM
handyandy's Avatar
handyandy
so whats the diff between a small and big.....besides size! is there a certain number c.i. that determines it?
Old Nov 12, 2006 | 08:17 PM
Kadence's Avatar
Kadence
the difference in a small block and big block is just like it sounds, small blocks are smaller and wiegh less with less displacement compared to big blocks. I beleive the cross over is around 400ci but there are some big blocks with less than that
Old Nov 12, 2006 | 08:27 PM
Colorado_Mustang's Avatar
Colorado_Mustang
Big block vs small block is based purely on physical size. Displacement is not a consideration, though big-blocks will typically have more displacement, although that is not a rule.
ORIGINAL: Kadence
Old Nov 12, 2006 | 09:18 PM
handyandy's Avatar
handyandy
A big block is heavier, but since it puts out more power than a small block, could a big block beat a small block with less power, even though it has more weight? (given that its the same car, with stock everything, i.e. an 01 GT if it could ever be done)
Old Nov 12, 2006 | 09:25 PM
ponysnake99
eh...its a hard question, but im going to make my stand on NO...because while it can make more power easily, it normally does not have as great a power/weight ratio or power/liter ratio...what i've always known big blocks for is MAD low-end torque
Old Nov 12, 2006 | 09:31 PM
BraMas's Avatar
BraMas
Close. I have Never seen a long block as a compete assembly. That usually falls under the crate motor category
short block = block and rotating assembly. meaning cam, crank and pistons
long block= block, rotating assembly and heads sometimes valve covers but not usually. You don't get any accessories or intake with a long block.
ORIGINAL: Kadence
Old Nov 12, 2006 | 09:37 PM
Kadence's Avatar
Kadence
i was trying to make it simple lol
