clutch question
Old Nov 15, 2006 | 04:56 PM
03dgsgt's Avatar
03dgsgt
Default clutch question
I have a question i have a 03 gt with 39000 miles i want to know how can i know when my clucth need to be replaced what are the signs i am asking this because is the first 5 speed is own i bought the car used please help thanks
Old Nov 15, 2006 | 06:32 PM
wes ley n the G T's Avatar
wes ley n the G T
Default RE: clutch question
Since you have a stock, non-adjusted clutch assembly, probably the easiest way of telling you need a new clutch is if the clutch doesnt start engaging until the very top of the pedal movement. Right now your clutch should engage/disengage towards the middle to bottom of the pedal. If it starts engaging/disengaging at towards the top, its a sign that you need a new clutch. Also, when you running your car hard and shift at higher RPMs, if you feel the clutch "slip" it means you need a new one. You'll feel the clutch not grab all the way or grab right away when you press it under high RPMs aka greater pressure for the clutch to work in. Hope this helps
Old Nov 15, 2006 | 06:51 PM
03dgsgt's Avatar
03dgsgt
thanks man i dont have that problem but my problem is that it grind a little from 1 to 2nd gear sometimes , they told me i could he the syncros or the clutch any ideas
AmericanMuscle4.6GT
Nov 10, 2015 02:06 PM
MasterLanMan
Sep 13, 2015 08:21 PM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
raleigh05GTO
Sep 4, 2015 07:09 AM
