Differant Procharger Install
Old Nov 16, 2006 | 06:34 PM
Emanpimpster's Avatar
Emanpimpster
Default Differant Procharger Install
Ok im assuming that a procharger and a vortech/paxton s/c mount in the same general area of the engine bay. Im planning on running a non intercooled procharger and just reclock the s/c and turn in down. Then just run the intake tube right to the TB. My question is, if they mount in the same place and have the same size discharge, would i be able to run, say a paxton intake tube from the procharger to the throttle body?
Thanks, Eric
Old Nov 16, 2006 | 06:43 PM
Emanpimpster
Default RE: Differant Procharger Install
plz
Old Nov 16, 2006 | 06:51 PM
ponysnake99's Avatar
ponysnake99
you could very well do that, im not sure the compressor ends are the same size, but you could check, and each tube is flow matched for the specific output of that company's system
you do know the only problem is doing this, you need to get a compressor bypass, bigger injectors, fuel pump, custom tune, belt, filter, intake pipe, MAF connector...if your up to that you'll have a very custom piece
Old Nov 16, 2006 | 06:57 PM
newb2000GT's Avatar
newb2000GT
I thought Vortec/Paxton mount on the driver side where as ProChargers mount on the passenger side. My ProCharger is on the passenger side, not sure about Vortec/Paxton completely.
Old Nov 16, 2006 | 07:41 PM
Emanpimpster
I think it depends on year. Looks like the intake tube for the vortech v1 t trim flows the same as the p1sc so i think that might work for me.
Granatelli Sales
Jan 20, 2020 12:34 AM
IronRaptor
Sep 9, 2015 08:10 AM
cbird1177711
Sep 2, 2015 04:12 PM
SYNY5TER
Sep 2, 2015 01:35 AM
