need help!!
Old Nov 21, 2006 | 09:18 PM
hardcore33's Avatar
hardcore33
Default need help!!
i have a 98 gt and it starts fine but when you think it is started an quit craning it it will quit. i think it is a run relay but idont no which one is the run relay i dont have my manual anyone no which one it is. there are 3.
Old Nov 21, 2006 | 09:24 PM
Chopper's Avatar
Chopper
Default RE: need help!!
Will it run if you give it gas with the gas pedal?If so it could be the IAC valve sticking closed or almost closed.A loose/disconnected vacuum hose will also cause this problem.
