6 speed tranny
Old Dec 3, 2006 | 11:47 PM
Guitarhead09's Avatar
Guitarhead09
Default 6 speed tranny
Im going to college soon, and im going to be driving on the interstate alot, well i already do, but im trying to get the rpms down and keep the gears in the car. Can i put a 6 spd tranny in my car? do they make one for my stang
Old Dec 4, 2006 | 12:04 AM
eventer289's Avatar
eventer289
Default RE: 6 speed tranny
Yes, its called the T56. It is about $2800 for an install package (driveshaft, new crossmember for tranny, tranny, etc.)
Old Dec 4, 2006 | 12:09 AM
gsxrstang69's Avatar
gsxrstang69
Yes. There are 2 different T56s. Theres the Viper Spec and the 03/04 cobra t56. Go to SVTPerformance.com and go into the SN-95 section. Search for this subject. THers at least 2 guys there that I know of that have done this swap.
Old Dec 4, 2006 | 12:14 AM
Guitarhead09
would this help bring down the rpms on the interstate , so i could keep the gears
Old Dec 4, 2006 | 12:26 AM
2000GT4.6's Avatar
2000GT4.6
ORIGINAL: Guitarhead09
A t-56 has nearly the same final gear ratio as your current transmission, so no it would not reduce your RPM on the highway.
The biggest advantage of a 6 speed is you don't get that massive falloff from 4th to 5th gear. This is why I stuck with a 5 speed when I did my tranny swap. I don't plan on racing above about 120 MPH anytime soon anyway
Old Dec 4, 2006 | 03:16 AM
Colorado_Mustang's Avatar
Colorado_Mustang
Look how much money you'd really be saving in the gas mileage difference (which isn't much, really). Changing the tranny just for that isn't really worth it....nor is swapping out gears.
Now, if you want to spend the money, swap in a 9 inch rear and get 2 different carriers, one with 4.11's and one with 3.00's. Then you could swap back and forth in just a couple hours and have the best of both worlds. Or, you could get a quick change rear end...
Old Dec 4, 2006 | 03:18 AM
2000GT4.6's Avatar
2000GT4.6
Once again, the 56 has a nearly (I think even identical to the 3650) identical final drive ratio to his 5 speed. You will not be seeing a signficant difference in highway RPM.
Old Dec 4, 2006 | 03:24 AM
Colorado_Mustang
Even if it were different, it wouldn't be worth it. There are T-56's with 0.50:1 final ratios.
ORIGINAL: 2000GT4.6
Old Dec 4, 2006 | 03:32 AM
2000GT4.6's Avatar
2000GT4.6
All of the 56 that I have seen offered for mustang swaps have the .64 or .67 (I forget) final ratio.
If you could get a .50 in 6th, along with a .80 or so in 5th, I think it would be worth it, simply because you could run 4.10s or 4.30s and still tach nothing on the highway.
Old Dec 4, 2006 | 05:21 AM
SINISTER's Avatar
SINISTER
Yeah, I agree that it would not be worth it, definitely not going to save you over $3,000 in gas.
