Traction
Everyone know that drag radials will cure traction problems for a stock car. When you get to 350 rwhp and up range sometimes tires just isn't enough. Just wanted to let everyone in on something I found out. I seen a supercharged Mustang GT hook street tires hard this weekend. All he had done was double adjustable coilovers and adjustable uppers with the pinion angle set at 3 deg. negative. The suspention on the front was stock. It just amazed me that he got 1.70 60fts from a street tire not a drag radial. He said it cost him about 800 dollars to cure all his traction problems. Sounds like a deal to me. My M/T drag radials hooked like that when they were brand new but thay give a little now with the wear and the cold weather. I figure if he can hook hard street tires then drag radials shouldn't come close to breakin loose. I'm gona try this setup. Has anyone else tried this?
Sep 8, 2015 11:50 AM
