Important Trans Filling Question
Old Dec 8, 2006 | 10:40 PM
Sap's Avatar
Sap
Default Important Trans Filling Question
So I emptied my transmission (03 GT, Manual Trans) using the drain plug at the bottom. I removed the shifter and filled it with about 3.75qt of ATF Fluid.
My question is :
1). I called the dealer to confirm that standard dexron ATF would be fine, he looked it up and said yes.
but I recall someone saying I needed to use synthetic?
2). Did I add enough ?
Thanks,
Eric
Old Dec 9, 2006 | 02:07 PM
Sap's Avatar
Sap
Default RE: Important Trans Filling Question
Anyone ?
Old Dec 9, 2006 | 06:48 PM
Colorado_Mustang's Avatar
Colorado_Mustang
Should be usin' Amsoil Synthetic ATF.[&:] Any synthetic is better than the other crap you can get.
Old Dec 9, 2006 | 08:21 PM
ut's Avatar
ut
I used Royal Purple SyncroMax and it took about 3.2 quarts (filled using the filler plug on the tranny). Sounds like you used plenty. Did you use a Mercon compatible fluid?
97SN95GT
Sep 13, 2015 09:45 PM
Sep 10, 2015 08:39 PM
zachary1988
Sep 4, 2015 03:04 PM
raleigh05GTO
Sep 4, 2015 07:09 AM
