heater doesnt work
Old Dec 11, 2006 | 01:22 PM
stunnaz916's Avatar
stunnaz916
Default heater doesnt work
i just bought a 1990 gt a couple days ago n i dont no really anything about mustangs. Well its pretty cold right now and my heater doesnt work and i have no idea why.... can someone give me some sugestions?
Old Dec 11, 2006 | 01:23 PM
monkeydude3's Avatar
monkeydude3
Default RE: heater doesnt work
with the engine up to operating temp, feel the inlet and outlet hoses that go to the heater core. If they are drastically different, it's clogged. If they both are warm, you probably have good flow and have a baffle / HVAC door problem.
Old Dec 11, 2006 | 01:45 PM
Js 99 GT's Avatar
Js 99 GT
Or you heater core leaks and someone just bypassed it, or you have no thermostat.
Old Dec 11, 2006 | 07:20 PM
tncruiser's Avatar
tncruiser
start simple replace the thermostat and make sure it faces the correct direction
Old Dec 11, 2006 | 08:19 PM
stunnaz916's Avatar
stunnaz916
aright thanks i will try all this
Old Dec 11, 2006 | 08:47 PM
sandcracker21's Avatar
sandcracker21
post back if any of this works, bc my girlfiends honda passport is havin the same problem
and i cant figure it out!
Old Dec 12, 2006 | 06:50 PM
GodAmGT00's Avatar
GodAmGT00
How about..
Add some coolant..
If your heater core has no coolant in it, then it won't get warm..
JT
Old Dec 12, 2006 | 06:55 PM
Js 99 GT's Avatar
Js 99 GT
ORIGINAL: GodAmGT00
How about..
Add some coolant..
JT
Yeah, good point. I had a car that the temp gauge got hot, but the heater core didnt. Had a coolant leak, and when the level got too low the heater wouldnt work, but you couldnt tell it was low by looking at the gauge.
Old Jan 22, 2007 | 05:04 PM
jrook's Avatar
jrook
what if it the thermostat has been replaced and the system has been flushed and heater core is good. What could it be then?
Old Jan 22, 2007 | 05:44 PM
redgt2000's Avatar
redgt2000
no coolant or low coolant = no heat
SSRFUZZY
Members Other Vehicles
Jan 6, 2016 08:22 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
JoshyGT
Sep 7, 2015 02:04 PM
cbird1177711
Sep 3, 2015 08:43 PM
Sep 1, 2015 08:16 PM
