removing headlights
Old Dec 12, 2006 | 12:37 AM
Brandons98GT's Avatar
Brandons98GT
Default removing headlights
I am wanting to change my clear headlights with black ones but i cant seem to see any bolts or anything to remove the ones in there already anyone have any easy ideas for that
Old Dec 12, 2006 | 12:39 AM
sitnlopro99gt's Avatar
sitnlopro99gt
Default RE: removing headlights
there should be two tabs on each headlight one on left and right you pull these up then disconnect wires they will slide right out
Old Dec 12, 2006 | 12:40 AM
handyandy's Avatar
handyandy
To remove the headlights, its easier than you would expect.
Pop the hood
Now you will see two sliding things that you pull on. Pull up these two latches (two per headlight) until they slide all the way out, they secure the headlights. And they slide right out. Twist out the head light bulbs though to completely remove it.
Old Dec 12, 2006 | 12:41 AM
ponysnake99's Avatar
ponysnake99
there are two pull tabs on either end of the light, there black, there's nothing to unbolt, just something to pull on
http://www.mustanghowto.com/PMP/Road.../Headlight.jpg
Old Dec 12, 2006 | 12:44 AM
BleedinBlue's Avatar
BleedinBlue
Is it the same for the 94-98's as the new edges? I've never looked at the headlights of an SN95 but since the lights are different, and the three previous responses were from other new Edge owners, I wonder.
Brandons98GT
my 98 doesnt seem to have those tabs that i can see
Old Dec 12, 2006 | 12:55 AM
sitnlopro99gt
edit this is how its done
look on the backside and first remove the metal clip on the top peg, looks like a fork. Then you will need some needle nose pliers and squueze the lower peg and pull on the headlight slightly. Wiggle and squeeze the peg together and the whole assembly will come out
Old Dec 12, 2006 | 01:36 AM
kcp1989's Avatar
kcp1989
Removing the headlights is the easiest thing to do on our cars.
Old Dec 12, 2006 | 01:29 PM
Brandons98GT
Ok i see these little black things with threaded bolts threw them it looks like there may be a tab that needs to be pushed in on 3 diff ones and then the light may pop out do i need to take the corner off first or will they come out together
Old Dec 12, 2006 | 02:13 PM
StangChik's Avatar
StangChik
take the corner out first, it will make it easier...and be careful not to damage those tabs with the needle nose pliers, you can't replace them. Everything else said above is correct. It took me a few times to get the adjustment right....that was a real pain.
