HELP WITH PROBLEM!
Old Dec 23, 2006 | 07:13 PM
memphissfinest's Avatar
memphissfinest
Default HELP WITH PROBLEM!
I just finished changing out my spark plugs and I noticed after i took off the coil over packs on the drivers side there was antifreeze in the hole with 3 of the 4 plugs on that side...what could be causing this?
Old Dec 23, 2006 | 07:15 PM
bleau's Avatar
bleau
Default RE: HELP WITH PROBLEM!
Check the intake manifold.
Mine cracked and was leaking into my plugs from where the heater hose went into the manifold.
Old Dec 23, 2006 | 07:27 PM
stang2000's Avatar
stang2000
oh, definately sounds like a cracked intake or head gasket. Any colored smoke coming out exhaust? It might not be bead enough yes, but get it checked out soon.
Old Dec 23, 2006 | 07:32 PM
memphissfinest
ok i guess ill go check the intake manifold and see what is up...brb
Old Dec 23, 2006 | 07:33 PM
Triisomy21's Avatar
Triisomy21
you're still not back....come on man get movin'!
Old Dec 23, 2006 | 07:40 PM
memphissfinest
i just did a quick visual check and i didnt see any cracks...maybe i should take it in to get it looked at.
Old Dec 23, 2006 | 07:45 PM
bleau's Avatar
bleau
Mine was really hard to see. I had some white crusty from the coolant tip me off.
Old Dec 23, 2006 | 07:47 PM
jmmorgan82's Avatar
jmmorgan82
run it until the coolant is nice and hot, then take a look and see if you see or smell anything, also check for bubbling in the reservoir
Old Dec 24, 2006 | 12:39 AM
memphissfinest
what could cause a crack in the intake manifold?
Old Dec 24, 2006 | 12:42 AM
Dan04COBRA's Avatar
Dan04COBRA
The fact that it's a plastic piece of crap.
