Cams
Old Dec 27, 2006 | 11:24 PM
99gtstang's Avatar
99gtstang
Default Cams
is this a bad idea for 117K.. also from what i have seen it is fairly easy if you know tools!
Is that correct
Old Dec 28, 2006 | 12:40 AM
99gtstang's Avatar
99gtstang
Default RE: Cams
Old Dec 28, 2006 | 12:42 AM
ZW99GT's Avatar
ZW99GT
Default RE: Cams
Its not the tools thats hard, its knowing what you are doing taking an engine apart and putting it back together.
Its not a simple in and out process. Theres nothing wrong with hi milage if its been maintained
Old Dec 28, 2006 | 01:16 AM
99gtstang's Avatar
99gtstang
Default RE: Cams
ORIGINAL: ZW99GT
Timing cover, pulleys, valve cover,alt, a/c comp, tensioners inside cover, cam caps? is that close?
well yea sounds like alot to do... seen an episode on horsepower few months ago on changing 99-04 cams i recorded will watch again...
maintained yes oil has been changed when needed plugs but i drive it pretty hard
Old Dec 28, 2006 | 01:32 AM
Aixtreme89's Avatar
Aixtreme89
Default RE: Cams
I found this write up! Will help solve all those questions on cam installs. It makes me want to get a set of ported heads......http://www.fordmuscle.com/archives/2...ot2V/index.php
Old Dec 28, 2006 | 09:14 AM
99gtstang's Avatar
99gtstang
Default RE: Cams
ORIGINAL: Aixtreme89
Thanks
Old Dec 28, 2006 | 10:12 AM
ripper's Avatar
ripper
Default RE: Cams
Thats a great article. Thnx
GimpyHSHS
19
Dec 19, 2023 01:12 PM
patchshaffer
Tuner Central
Oct 5, 2015 02:24 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
junior04
Sep 28, 2015 10:53 AM
Ryan Fitzpatrick
Sep 14, 2015 02:21 AM
