BULLETPROOF? Help me out
Old Jan 2, 2007 | 07:12 PM
ZW99GT's Avatar
ZW99GT
Default BULLETPROOF? Help me out
Im looking for a bulletproof drivetrain. Imnot worried aboutmy engine, so I will start at the clutch and work my way back.
Heres what I'm planning to do. If you see anything I've missed, or something that would be better, let me know. I'll be looking for 1.60-1.75 60ft's on Slicks.
This will be asked to handle 500+rwhp(and even more torque)on the weekends at the track.
Spec stage 4 clutch
TKO 500
Moser c-clip forged Axles (staying 28 spiline)
Will my driveshaft be a problem? Thanks guys.
Old Jan 2, 2007 | 07:17 PM
code3GT's Avatar
code3GT
Mustang Nazi
Default RE: BULLETPROOF? Help me out
ORIGINAL: ZW99GT
Spec stage 4 clutch
TKO 500
Eaton posi, weld TQ boxes, upper/lower CA's and sub-frame connectors...don't forget about the flywheel.
Old Jan 2, 2007 | 07:25 PM
ZW99GT's Avatar
ZW99GT
ORIGINAL: code3GT
ORIGINAL: ZW99GT
Spec stage 4 clutch
TKO 500
Exactly what I needed to know. I know about the suspension parts already. Im just looking at what I need to buy for my drivetrain. What kinda flywheel should I be looking for? forged? Lighter? heavier? Ive never heard of replacing that.
Old Jan 2, 2007 | 07:27 PM
code3GT's Avatar
code3GT
Mustang Nazi
ORIGINAL: ZW99GT
ORIGINAL: code3GT
ORIGINAL: ZW99GT
Spec stage 4 clutch
TKO 500
I run the same aluminum flywheel used in the 2000 Cobra R.
Old Jan 2, 2007 | 07:28 PM
Dan04COBRA's Avatar
Dan04COBRA
You are staying with IRS right? I thought the IRS was stock 31 spline?
Old Jan 2, 2007 | 07:29 PM
2VNA's Avatar
2VNA
code would be the best to anwsor that there are alot of co's that say there the best but it is a change I am going to make when I replace my clutch. I think that they weigh aroud 12LBS and use less energy to move
Old Jan 2, 2007 | 07:39 PM
ZW99GT's Avatar
ZW99GT
ORIGINAL: Dan04COBRA
Im going SRA. Should I just go ahead and go 31 spline? It dont make a **** to me. I've already found an SRA that I'm just gonna build thehellout of. This will be a slow process, but I just need a list of everything I willneed. I'm going big, and Ijust dont want to overlook any part of thedrivetrain. This rear will not be out in until it is up to the challenge. So now heresthe updated list
Spec stage 4 Clutch
TKO 500
Moser forged axles
Eaton posi
weld TQ boxes
Upgraded flywheel
Better? Will my regular old FRPP 4.10's take this kinda power?
Old Jan 2, 2007 | 07:49 PM
code3GT's Avatar
code3GT
Mustang Nazi
ORIGINAL: ZW99GT
Spec stage 4 Clutch
TKO 500
Moser forged axles
Eaton posi
weld TQ boxes
Upgraded flywheel
Gears will be fine.
Old Jan 2, 2007 | 07:59 PM
ZW99GT's Avatar
ZW99GT
Good, thats one of the few things on this drivetrain that I wont have to upgrade. This **** is nuts. Its not really that hard to go fast, its just hard as hell to go fast without worrying about breaking stuff.
Old Jan 2, 2007 | 09:41 PM
99mustanggt's Avatar
99mustanggt
While you got everything apart you may as well put an aluminum driveshaft in it.I've seen them twist in half before,looks cool but not fun.
