UDP's arrived today
Today was a good day, I got home from work and my UDP's pullies had arrived along with my new HPS hawk brake pads and some extra RP rear end fluid I had ordered
. So now I got some stuff to install, hopefully gonna try to get it done by the middle of january.
The list of mods going on is
1- Steeda UDP's
2- New set of Brakes pads all around
3- MM Sub frame connectors
4- Motive 3.90 gears with a motive bearing kit
5- Summit 8.8 Rear end support cover
6- Eaton Posi limited slip 8.8in 31 spline differential
Now im hoping theseparts arecompatable with my stock axles can anyone tell if they are? If not I will have to order me a set of moser 31 spline axles which I was debating weither to or not jus to do them anyway. Im planning to build upmy rear end and suspension as my first few mods. Here some pictures of my stuff waiting [>:]to be installed. Any tips for me I will be installing the UDP's, Brakes, Sub frame connectors myself but the gears and posi will be done by Steeda. Man o man I can't wait to get this stuff installed lol.
. So now I got some stuff to install, hopefully gonna try to get it done by the middle of january.The list of mods going on is
1- Steeda UDP's
You will most definately have to get axles. They arent that High..
Takes alot of self control/responsibility to build up a cars suspension and rear BEFORE power mods. I wish I woulda done that.
P.S. or you could send the Posi back. You could grab this.
Eaton TM Posi, DS 19588-010 28 Spline
Instead of what you have which is(DS19605-010 31 spline)
ORIGINAL: ZW99GT
r those hawk brake pads really good. the brake pads i have r from kragen n damn they leave my front rims black from all the dust why is that? is it cuz its a cheap pad or what. say i washt the car today the rim would be black by fri
