mach 460 question
Old Jan 4, 2007 | 08:04 PM
jst854's Avatar
jst854
Default mach 460 question
hey guys, not sure if this is in the right place or not but, on the mach 460 i know that you can not do that much without redoing the whole system. My question is if it is possilbe to just replace the stock speakers with better ones since the system already had amps i think it would sound pretty good. What do you guys think about this.
Old Jan 4, 2007 | 08:10 PM
Aixtreme89's Avatar
Aixtreme89
Default RE: mach 460 question
I was confronted with the same issue. I blew a front speaker. I went to one car audio shop and he said I cant change anything, if I did I would have to replace everything... Then some people say not true. I email crutchfield.com with my question. They replied with, you can replace the factory speakers. But you cant replace the headunit without replacing the amps and having to rewire the speakers. I bought a cheap speaker for my door and it works fine.
Old Jan 4, 2007 | 08:14 PM
jst854's Avatar
jst854
awesome, would you happen to know the speaker sizes
Old Jan 4, 2007 | 08:19 PM
Aixtreme89's Avatar
Aixtreme89
Its a 6x8 you can also buy adapters to make it a 5 1/4" and I believe with a little tiny bit of cutting you can put 6 1/4" in. I want to get a set of 6 1/4" component speakers all around.
Old Jan 4, 2007 | 08:25 PM
jst854's Avatar
jst854
6X8 all around or just upfront?
Old Jan 4, 2007 | 09:28 PM
GreyStang's Avatar
GreyStang
I thought all the speakers in the Mach 460 were 2 ohm? So, you're sticking aftermarket (usually 4 ohm) speakers in their place? And it sounds ok? How about when you crank it up?
Watch out you don't smoke an amp running 4ohm speakers
1BAD3V
Tennessee Regional Chapter
Oct 6, 2016 12:12 PM
PaulH2
20
Jan 31, 2016 09:48 AM
Sixer4Life
Sep 29, 2015 07:03 PM
treesloth
Sep 28, 2015 07:03 AM
1BAD3V
Indiana Regional Section
Sep 26, 2015 09:03 AM
