engine removal
Old Jan 5, 2007 | 04:21 AM
BatMobile00's Avatar
BatMobile00
Default engine removal
hey anyone know the best places toput the chains to lift out a motor? I couldn't find any brackets....
Old Jan 5, 2007 | 04:54 AM
BatMobile00
Default RE: engine removal
i cant believe i have to bump this.. no one knows!?
Old Jan 5, 2007 | 07:42 AM
Aixtreme89's Avatar
Aixtreme89
I wondered the same thing a while back when I was doing my longtubes.... Well I have seen pictures of one guy taking a strap and wraping it around the headers, two straps. Then I saw this article and it looks like they have it bolted to the front timing cover and the rear bolts for the bellhousing. http://www.fordmuscle.com/archives/2...ct01/index.php
Good luck.
Old Jan 5, 2007 | 12:53 PM
Js 99 GT's Avatar
Js 99 GT
I think you need to use a brackt that you can adjust the angle of the motor. If you just want to pull it and move it around by hand just bolt it to an intake bolt, but take the intake off before and make sure its screwed all the way down. You may ruin the bolt, so just be prepared. I havent pulled this motor yet, but many have brackets you can just hook a chain hook to, you might go look for some of those from a parts store.
Old Jan 5, 2007 | 03:49 PM
BatMobile00
um, has anyone actually DONE this??? I should be yanking the motor tonight.
Old Jan 5, 2007 | 03:57 PM
SINISTER's Avatar
SINISTER
Try giving Ford a call to see what their mechanics do. Talk to one of them in the service department, they should be able to give you some pointers/guidance.
Old Jan 5, 2007 | 04:07 PM
BatMobile00
ok, and since no one knows, I will enlighten you all once I find out
Old Jan 5, 2007 | 04:11 PM
jmmorgan82's Avatar
jmmorgan82
i've seen people pull motors with a lift plate that bolts on where the upper intake plenum is, but I don't think our plastic intakes could hold up to that. please do post what you find out as i am very curious about this. Sorry I dont have an exact answer for ya.
Old Jan 5, 2007 | 04:12 PM
doughboy4.6's Avatar
doughboy4.6
I will tell you how I do mine I pull the intake and use 2 intake bolts and put the bolts trew a socket and bolt one down to the drivers side head in the front and one in the passenger side head in the back and lift
Old Jan 5, 2007 | 04:27 PM
Js 99 GT's Avatar
Js 99 GT
ORIGINAL: BatMobile00
I have pulled plenty of motors, I was just saying I saw where someone had used a bracket that they could adjust the angle tomake it easier. Do as doughboy said, thats how everyone pulls a motor. I was just trying to make your life easier, I hear the engine compartment is crapmped and the adjuster helps. Do you even have a cherry picker hoist?
