Dyno today.
Old Jan 6, 2007 | 05:56 PM
Red 5's Avatar
Red 5
Default Dyno today.
I went down to OPA today for Dyno Day. I'm pretty happy with the results. Do my numbers look about right for my mods?
Performance Mods:
Full length Densecharger cai with 85mm mam
Accufab 70mm Throttle Body & Plenum
Steeda underdrive pulleys
SLP Long Tubes
SLP x-pipe w/ cats
SLP LM 2’s
KYB Struts
Eibach Sportline Springs
Granatelli upper and Lower Control arms
Monroe Foxbody shocks
SPEC Stage 1 Clutch
SPEC Aluminum Flywheel
MGW Short Throw
Old Jan 6, 2007 | 06:01 PM
Dan04COBRA's Avatar
Dan04COBRA
Default RE: Dyno today.
Your numbers suck, your A/F sucks even more. Time for a tune.
Old Jan 6, 2007 | 06:04 PM
Red 5's Avatar
Red 5
ORIGINAL: Dan04COBRA
Your mom.. JK
What should I be seeing? My A/F was around 11. I plan on a tune as soon as I gat the cash.
Old Jan 6, 2007 | 06:10 PM
Dan04COBRA's Avatar
Dan04COBRA
You should be seeing 270-275RWHP, maybe a little more torque.
Your A/F looks like it's all over the place too.
Old Jan 6, 2007 | 06:13 PM
Aixtreme89's Avatar
Aixtreme89
I think your numbers are pretty good... Your AF ratio is very rich, you need to get a tune.... How do you like your aluminum flywheel? Does your motor rev up faster, did you get better aceleration? Do you have stock gears in the rear? Spec said with 4.10's theres no problem bogging, but with the stock gears you might have to slip the clutch a bit to get it going? What are your opinions?
Old Jan 6, 2007 | 06:15 PM
Dan04COBRA's Avatar
Dan04COBRA
Lightweight flywheel with stock gears would be a little harder to get it going, that's one advantage to a heavier flywheel, it'll be able to get the car moving quicker, but from a roll...you get the idea.
With 4.10 gears it'll be fine with a lightweight flywheel.
Old Jan 6, 2007 | 06:17 PM
Red 5's Avatar
Red 5
I do think the acel is quicker with the alum fly. I do have stock gears.
Old Jan 6, 2007 | 06:19 PM
Dan04COBRA's Avatar
Dan04COBRA
It def helps, but in a perfect world with 2 fully equal cars & drivers, the stock flywheel car would have a little advantage until you got going 60+.
If you were looking for 9's at the track, it'd be worth debating which is better.
Old Jan 6, 2007 | 09:30 PM
99mustanggt's Avatar
99mustanggt
Your numbers dont look to bad to me. You are running rich though.
Old Jan 6, 2007 | 09:44 PM
Machwon's Avatar
Machwon
yeah get a SCT or Diablo tune, lean it out to around 12.5 and you should see 10-15+ at the wheels. Tunes- when done by a good tuner are worth their weight in gold. I picked up 27 at the wheels in my mach 1.
