Big Problem
Old Jan 11, 2007 | 02:46 PM
*Blk_96_Stang_GT*'s Avatar
*Blk_96_Stang_GT*
Default Big Problem
im doing my PI swap and i just finished putting the timing chains back on, everything is how it should be (99% sure) and when i started turning the crankshaft to make sure everything went around as it should, right when #7 gets to the top i hear a little thud and i can't turn it anymore, is that the piston hitting the valves?
Old Jan 11, 2007 | 03:28 PM
Js 99 GT's Avatar
Js 99 GT
Default RE: Big Problem
Sounds like it. Can you turn it the other way?
Old Jan 11, 2007 | 03:32 PM
slow99GT's Avatar
slow99GT
Umm i dunno but it doesnt sound to good.. hopefully its just a little small mistake somewhere..
phalcrow's Avatar
phalcrow
Are your cams on the correct sides? They are left/right specific. Also, here's what I used to time it. http://www.modulardepot.com/?show=ar...det&aid=32
Old Jan 11, 2007 | 03:38 PM
*Blk_96_Stang_GT*
well i thought i could turn it the other way until the same spot agin but i guess not, same thing happens when i think it was #2 comes up. I guess im just gonna have to mess with the timing chains until i get it right, even though i have everything lined up like it should.[]man this is frustrating, i suggest none of you try this at home, unless you have a lot of exsperience not the easiest thing to do.
Old Jan 11, 2007 | 03:42 PM
SVTBill's Avatar
SVTBill
ORIGINAL: *Blk_96_Stang_GT*
you have any pictures of this? im assuming #2 is the companion cylinder of #7?
Old Jan 11, 2007 | 03:51 PM
99mustanggt's Avatar
99mustanggt
Yeah, that definately sound like piston and valve interference. Just take the chain back off and make sure you timed it right.
*Blk_96_Stang_GT*
no it goes from the front left 1-2-3-4 and then on the drivers side 5-6-7-8 so 7 and 3 would be across from each other
Old Jan 11, 2007 | 03:53 PM
contentsunderpressur's Avatar
If your running stock cams then your timing has to be off, or there'sa bolt or something on top of your piston. A performance shop near me done an engine swap in a 98 and had the exact same problem. It was the timings. In the end it'll be worth the trouble. Good luck
Old Jan 11, 2007 | 04:03 PM
Sam 07's Avatar
Sam 07
thank goodness you didnt crank it! good possibility your timing is off
