what exactly does this error code mean
P1506 Idle Air Control Over Speed Error, i just got what it is supposed to mean from the error code post on here but i am not sure what exactly it means in stupid people terms, can anyone explain.
i have a code description for PO506:
description: the pcm attempts to control engine speed during KOER self-test. the test fails when the desired rpm could not be reaced or contrlled during the self-test
possible causes:
- iac circuit shorted to pwr
-vpwr to iac solenoid open
- iac circuit open
-damaged iac valve
-damaged pcm
- air inlet is plugged
diagnostic aides
the iac solenoid resistance is from 6 to 13 ohms. monitor iac pid duty cycles and/or voltage.
hope this helps!
possible causes:
- iac circuit open
-damaged iac valve
-damaged pcm
diagnostic aides
hope this helps!
