Brake Problem...
Old Jan 25, 2007 | 06:19 PM
03sonicgt's Avatar
03sonicgt
Default Brake Problem...
Alrighty guys, this problem started about2 months ago when my brakes started squeaking so I got some new pads and rotors. But the squeaking is still here, but the thing is when I push on the breaks the squealing stops. It sounds as if something is if rubbing against the pad and when I close the caliper the squealing starts. Do you guys have any ideas as to what this noise is??
Old Jan 25, 2007 | 07:54 PM
03sonicgt's Avatar
03sonicgt
Default RE: Brake Problem...
Anyone??
Old Jan 26, 2007 | 12:01 AM
oxfordgt's Avatar
oxfordgt
Pull your wheels and spray break cleaner all over the roters and calipers. Then put some desqueak on the rotors. If that doesn't work take it to get looked at.
Old Jan 26, 2007 | 12:33 AM
beastzilla02's Avatar
beastzilla02
yes i would love to know..same thing is going on with mine.
Old Jan 26, 2007 | 12:37 AM
TR03GT's Avatar
TR03GT
I ♥ Acer
Mine were squeaking when I got my car a few weeks ago and the rotors were new. The owner said they only had 1000 miles on them. I took it to a brake shop and they re surfaced them and now they are fine.
Old Jan 26, 2007 | 04:19 AM
03sonicgt's Avatar
03sonicgt
Maybe a re-surfacing is the trick...
Old Jan 26, 2007 | 04:28 AM
St4ng07's Avatar
St4ng07
Well..if it stops when you hit the pedal. Might be a bent backing plate?
Old Jan 26, 2007 | 04:39 AM
dlazrael's Avatar
dlazrael
mine had this same issue, and the ebrake boss spring and retaining nut broke off (this is bad, i I know) and the squeaking has stopped, try adjusting the ebrake cable, it might be dragging some
Old Jan 26, 2007 | 04:50 AM
rbstang's Avatar
rbstang
i know sometimes the pad comes unglued from the caliper and it will squeak until you hit the brakes then it squeezes them hence stopping the squeaking...
Old Jan 26, 2007 | 12:22 PM
Brute03's Avatar
Brute03
i have the same thing going on with my right-front brakes, but i'm just too busy/lazy to strip it down
