why
Old Jan 31, 2007 | 02:57 AM
mustanggtrider's Avatar
mustanggtrider
Default why
why does everyone upgrade the T45 and go with the T56 and also how do u know the difrence between the clutch goin or the transmission goin bad this is my first stick.Sometimes it grinds o gotta play with it to go in rev and it seems real easy to slide the shifter in and out of gear.The pedal is nice ad stiff thoe
chris
Old Jan 31, 2007 | 03:00 AM
Quickshift_02GT's Avatar
Quickshift_02GT
Default RE: why
Tranny sounds like the problem.
Someone else can fill you in on T56 over T45. I assume it's stronger, but I'd be guessing.
Old Jan 31, 2007 | 03:07 AM
mvr's Avatar
mvr
Default RE: why
what year is your mustang? sounds like the common problem the tr3650 has with grinding gears when cold.
Old Jan 31, 2007 | 03:08 AM
1fast50's Avatar
1fast50
Default RE: why
t56 is a lot stronger.. and it is a 6-speed.. the t45 isnt as strong.. my t45 does the same thing. It grinds goin into second sometimes.. so i hella baby it..
Old Jan 31, 2007 | 03:14 AM
Quickshift_02GT
Default RE: why
Ah, yes. I'm forgetting all the common Mustang issues already.
The TR3650 transmission has a lot of problems with 2nd and 3rd gear grinding. There was actually a TSB from Ford about it. Within certain mileage, you can get it fixed at a dealer for warranty replacement. The issue has to do with the 2nd and 3rd synchros and forks, if I remember right. As far as reverse goes, I remember mine was rather difficult on a regular basis as well. I found that if I went up to first gear, then down to reverse it worked perfectly 90% of the time. But straight into reverse was a bitch most times.
And like the other guys said, yeah...six speed and fairly tough.
....what year mustang do you have?
Old Jan 31, 2007 | 03:17 AM
mustanggtrider
Default RE: why
its a 96gt t45 I just want it to last as long as i can. If not cant i make it real strong to hold it up i know cobras have it so it must have some pluses
Old Jan 31, 2007 | 03:21 AM
rbstang's Avatar
rbstang
Default RE: why
t56 is a 6spd thats one of the pluses... if i was going do a big tranny swap id get the t56 viper tranny just to be like i have a viper tranny and you dont haha or a tko500/600
http://www.ddperformance.com/
they sell kits
Old Jan 31, 2007 | 03:25 AM
Quickshift_02GT
Default RE: why
Oh, 96GT....
Ignore everything we said about the 3650...
Old Jan 31, 2007 | 03:28 AM
racer02GTstang's Avatar
racer02GTstang
Default RE: why
im running the tko500 pro750... its a very strong built tranny, no problems so far with some track runs in with sticky D/R's and some street abuse too.
ORIGINAL: rbstang
http://www.ddperformance.com/ they sell kits
Old Jan 31, 2007 | 03:29 AM
bransdaman78's Avatar
bransdaman78
I ♥ Acer
Default RE: why
ORIGINAL: Quickshift_02GT
thats because the manual says to put it in a forward gear before shifting into reverse, every time.. I go 1st 4th R
