Cams
Old Feb 7, 2007 | 12:40 PM
znasrah's Avatar
znasrah
Default Cams
I'm having trouble finding outwhere I can find a stage II cam.. and also how much am i looking to spend on the cam and then on the installation..
Old Feb 7, 2007 | 12:56 PM
ASUSMC's Avatar
ASUSMC
Default RE: Cams
VT has your cams. I don't know what car you have so I can't give you a link.
Every shop I have talked to in the Phoenix Area has quoted around 2500 for the install. They tell me to do it CORRECTLY you are supposed to pull the motor.
Old Feb 7, 2007 | 01:12 PM
Chopper's Avatar
Chopper
Default RE: Cams
No you don't have to pull the engine,although the front cover should come off just so you can precisely degree the cams.
Another expense you might want to consider would be the cost of a programmer and tune.Comp Cams even suggest a tune (programmer) with 262's now.
Handheld programmer $400
Dyno time.around $100 hr.
Some dyno operators use a specific tuner so check with your friendly neighborhood dyno man before you buy a tuner.
Old Feb 7, 2007 | 02:09 PM
1hotdrp's Avatar
1hotdrp
Default RE: Cams
i got a quote from a local shop of $750 for cams and springs
GimpyHSHS
19
Dec 19, 2023 01:12 PM
patchshaffer
Tuner Central
Oct 5, 2015 02:24 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
junior04
Sep 28, 2015 10:53 AM
Ryan Fitzpatrick
Sep 14, 2015 02:21 AM
