more boost??
what would i have to do to atleast run 15 lb of boost on a 2003 mustang gt?i know i would have to chang the block cause a stock block will not hold over 9 lb of booost what would be the cheapest way to atleast run 500-600 hp??what type of block should i use 302 or 351??and how much do u think this will all cost?
VT shortblock $3500 and up.....my friend that i bought my blower from put on a 15psi pulley on the dyno for the hell of it and took the risk and made over 500 to the wheels with only an x pipe ,catback and 75mm tb in addition to the blower.....
You wont have to change the block itself, just the shortblock. Rotating assembly. Forged Pistons, rods, crank, etc........ Kits can be had for less than 2k. After that, it will take 15psi all day.
ORIGINAL: Speeder_069
Assuming you already have a blower kit with the stock shortblock, you are gonna need more than a shortblock to hit the power levels you want. you will also need to upgrade the fuel system and injectors, and replace the stock MAF if your still running it. Its not exactly cheap to go from a stock shortblock car to a 550+ WHP built motor car.
so all together about 6500 dollors i should have about 500 to the real wheels...just a stroker kit and a supercharger and im done..i already have x pippe with no cats
