Yea just seeing if anyone else is haveing this problem and if they know how to fix it. My driver side window seems to catch on something and squeak every once and a while, going down and up. Just the driver side window. Any know how to fix it or what causes it?
I think there are felts in the window that just need to be loosened. They are slideable once you loosen the bolt...there is 2 of them I think inside the door...that should solve it. Do you guys have tints cause I notice it is more common after that. Mine do not do it knock on wood but my brothers 02 does it with his tints Dan
If there is no scratching on the glass, take a rag with some window cleaner, roll down your window all the way and clean the seals. Then clean the seal closest to your side mirrors @ the front of the door.
