Traction Control
Old Feb 24, 2007 | 04:09 AM
Blacksslumina's Avatar
Blacksslumina
Default Traction Control
I just bought this 04 Gt Vert. Stang, the traction control button is not present in the car, just the little dud cover. Do all gt's have traction control? or is it optional? if i put the trac. control push button in will it work?
Old Feb 24, 2007 | 04:21 AM
sprostang's Avatar
sprostang
I ♥ Acer
Default RE: Traction Control
It`s an option. Really, be happy that you don`t have it. It sucks.
Old Feb 24, 2007 | 04:22 AM
SVTBill's Avatar
SVTBill
that means you dont have ABS either, they work off each other
Old Feb 24, 2007 | 04:26 AM
ZW99GT's Avatar
ZW99GT
ORIGINAL: SVTBill
Are you sure? I'm fairly sure I have ABS. And no t/c.
Old Feb 24, 2007 | 04:27 AM
devsredgt's Avatar
devsredgt
ya thats what sucks about not having it.
Old Feb 24, 2007 | 04:31 AM
Tylus's Avatar
Tylus
what does the T/C do for you honestly? from what I've seen so far, all it does is cut back engine power when wheel spin is detected. Right? I'm 50/50 right now on whether I like it or not. My 6000# F-150 needs a good shot of gas to get going. I gave my car an equal amount of throttle with the T/C off and I just sat there roasting the tires. I had to do it again just to make sure.
Old Feb 24, 2007 | 04:33 AM
sprostang's Avatar
sprostang
I ♥ Acer
ORIGINAL: SVTBill
WRONG! You can have ABS without T/C .
Old Feb 24, 2007 | 04:35 AM
SVTBill's Avatar
SVTBill
ORIGINAL: ZW99GT
ORIGINAL: SVTBill
Yes, they are a package deal. The reason why some don't have t/c is because it would have costed Ford money to put it in because the car would have had to have abs also. So, they save a few cents by not putting them in.
ABS and TC use each other, can't have one without the other
Old Feb 24, 2007 | 04:36 AM
SVTBill's Avatar
SVTBill
ORIGINAL: sprostang
ORIGINAL: SVTBill
its possible but the new edge mustang is not that way you big smelly
Old Feb 24, 2007 | 04:37 AM
cahtr6's Avatar
cahtr6
Absolutely my 2004 T/Chad to be removed by a handheld and then by K/B no button
