engine knock, rods?? valves??
Old Feb 25, 2007 | 10:05 PM
jnobles's Avatar
jnobles
Default engine knock, rods?? valves??
http://media.putfile.com/engine-knock-22
happened after spark plug decide to disengage from head while driving...wasn't driving hard
Old Feb 25, 2007 | 10:17 PM
badboystangGT's Avatar
badboystangGT
Default RE: engine knock, rods?? valves??
yes sir thats rod knock for you probably bent the rod sounds exactly like what happened to mine and look what happened
Old Feb 25, 2007 | 10:34 PM
kenv's Avatar
kenv
I`m trying to figure out how spitting out a plug could cause a bent/broke rod.
Old Feb 25, 2007 | 10:40 PM
oxfordgt's Avatar
oxfordgt
sounds like a spun bearing to me.
Old Feb 25, 2007 | 11:09 PM
jnobles's Avatar
jnobles
not sure how a plug caused that. I was driving under the speed limit as a matter of fact.....heard and boom and pulled over immediately called for a tow mechanic said the number 8 plug was spit out. They helicoiled it and this is what it sounded like when when it started up
Old Feb 25, 2007 | 11:16 PM
oxfordgt's Avatar
oxfordgt
Use a stethescope and listen to the spark plugs. If #8 is louder then the rest then they did a bad job on the helicoil.
Old Feb 25, 2007 | 11:34 PM
jnobles's Avatar
jnobles
what should I do then???
Old Feb 25, 2007 | 11:42 PM
badboystangGT
your gonna have to rebuild it you bent the rod you should just be able to open up the bottom end and replace the the rods and the rod bearings
Nick Oliver
Oct 17, 2018 04:22 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
zanemoseley
Sep 6, 2015 12:58 PM
RWHEELS
Sep 5, 2015 03:42 PM
Sep 1, 2015 08:16 PM
