HID Install
Old Feb 27, 2007 | 05:44 PM
josh662234's Avatar
josh662234
Default HID Install
I got my HID kit today, used, and i have figured everything out except for one blue wire coming off of the blue plug that plugs into the old headlight bulb spot. . . does anyone know where this might go?
Old Feb 27, 2007 | 05:52 PM
sitnlopro99gt's Avatar
sitnlopro99gt
Default RE: HID Install
What brand are they. should just plug right into everything you took off you have pics? Also you go to school in NH or MA cause Igo to school inManch
Old Feb 27, 2007 | 05:53 PM
josh662234's Avatar
josh662234
ill take pics. . . be back
Old Feb 27, 2007 | 07:25 PM
laserred38's Avatar
laserred38
your old headlight connector should plug into the blue connector...it depends on the kit...mine only had enough length on the power wire to use the driver's side headlight connector...i just wrapped some electrical tape around the old passenger side connector....i have a bi-xenon kit (high/low beams) so i have 4 ballasts...mounted the driver's side two stacked...tucked in front of the battery....mounted the passenger side two flat (side by side) underneath the air intake (pretty much right under the filter on the flat part...i didn't drill or anything...just used double-sided tape and zipties to secure them...they aren't going anywhere...oh yea i grounded the kit under one of the bolts on the fender too
PM me if you need more help...you can give me a call if you have other questions (PM me if you need help and i'll give you my cell)
mtgldr
Feb 3, 2024 09:00 PM
BOBCATJACK
Sep 14, 2015 02:18 AM
Sep 10, 2015 08:39 PM
Mobiusone stang
Sep 7, 2015 08:46 PM
