00GT Misfiring!!!HELP!!!!!!!!!
ORIGINAL: mattmoto441
did you car is in the rain?? if so pull your coils and get the water out of the spark pulg valleys and do this with brake clean and you should be set if the coil hasnt burnt out by arking over, that is the #1 killer of coils in thestangs
Did you car sit in the rain? Or did you power wash your motor?? If so pull your coils out and there might be water in the hole/valley the spark plug is in, and its causing the coil to arkover in the water and not sparking the plug causing the misfire. To get the water out of the spark plug hole/valleys and you can start by taking out the spark plug and spay brake clean in the hole/valley you do this with brake clean b/c it leaves no residue, if the coil hasn't burnt out yet by arkingover this should fix your problem, that is the #1 killer of coils in the stangs
Omgitsa88Stang
Oct 5, 2015 07:33 AM
