motor falls flat on its face, Help
Old Feb 28, 2007 | 12:36 PM
Jennings Racing's Avatar
Jennings Racing
Default motor falls flat on its face, Help
I just got this 02 GT 4.6 5speed last week.And the last couple of days the motor fills like it just falls flat,studers.It does it sometimes just driving down the road normal,and then other times it does it when I get on it.The car only has 31,000 miles.I think its the fuel filter,or fuel reg.,and now the service engine soon light goes on and off.What do you guys think.Thanks Tanner
Old Feb 28, 2007 | 12:39 PM
kendiesel's Avatar
kendiesel
Default RE: motor falls flat on its face, Help
Fuel filter or fuel pump. Does it studder when u accelerate.
Old Feb 28, 2007 | 12:48 PM
Jennings Racing
It does sometimes,It will do it in the middle of accelerating
Old Feb 28, 2007 | 12:49 PM
Davojan59's Avatar
Davojan59
ive had that on my 99 and it ended up being a misfire in cyl. 5. Does it kinda shake when u accelerate?
Old Feb 28, 2007 | 12:51 PM
kendiesel's Avatar
kendiesel
fuel filter or fuel pump but if ur check engine light comes on it could be a misfire in one of ur cylinders. Check ur plugs and coils before the fuel filter and fuel pump.
Old Feb 28, 2007 | 12:58 PM
Jennings Racing
Ok I'll do that,what fuel do you run in these cars 87,89,91.My Z3 ran 89.I think this car has 87 in it could that be the problem.
Old Feb 28, 2007 | 01:02 PM
kendiesel's Avatar
kendiesel
ORIGINAL: Jennings Racing
Depends on what u have it tuned for. If you have no mods and its stock then 87 should be fine
Old Feb 28, 2007 | 01:05 PM
disturbed471985's Avatar
disturbed471985
Go cheap first check plugs!!! Then change fuel filter!! Ill put my money on the fuel filter prob still has the factory on it.
Since no check engine light comes on i wouldnt think it would be a misfire!!
Then ur running stock so 87 is just fine. Unless ur timing has been messed with!
Old Feb 28, 2007 | 01:06 PM
Jennings Racing
The only motor mod I see is a K&N filter,If you want to call that a mod.I don't think any thing else has been done to the motor.
Old Feb 28, 2007 | 01:07 PM
Brute03's Avatar
Brute03
it only needs regular fuel. i would go ahead and give it a tune up (plugs, fuel filter etc) and getthat code pulled
