axle code
Old Oct 31, 2004 | 01:07 AM
white 98 gt's Avatar
white 98 gt
Default axle code
anybody know the axle code for my car? sticker on the door jam says LE. has the 17 inch rims. don't know if that matters. thanxs..
Old Oct 31, 2004 | 01:50 AM
Casper98GT's Avatar
Casper98GT
I ♥ Acer
Default RE: axle code
Well, looks like 4 people have looked at this and havent helped you out. So here it is. Im guessing you mean code, as in axle ratio. Look at youre rear differential. On it you will see a axle tag. Its held in place by a diff cover bolt. 13 mill. bolt. Remove this and you can look to see as to what gears you have in it. OK. Good luck
Old Oct 31, 2004 | 02:09 AM
96GT70SS's Avatar
96GT70SS
no, dont do that....there is a tag on the right side (passenger) of the rear end...yep u gotta crawl under ur car.....there are TWO (2) lines.dont pay attention to the top line...look at the bottom like....mine says
3L27 8 8
that means 3.27:1 posi (or limited slip)...the 88 is obviously 8.8" rear end (in terms ...technically, that means the RING gear is 8.8" (dia))....
ther code reads left to right just like i typed it...if its a gt it will say either
3L27
2L73
3L08
in terms 3.27 or 3.08 or 2.73....you REALLY want 327...or 308 it ok too.....273 are highway gears...good for gas mileage and nOTHING but!
Old Oct 31, 2004 | 11:43 PM
white 98 gt
yep, meant axle ratio..... thanks for the help guys.
BOB ROME
Jul 26, 2023 01:54 PM
mrtrodonet
Sep 19, 2020 03:12 PM
Dathan
Oct 5, 2015 05:52 AM
KingRando
Oct 2, 2015 08:06 AM
Sep 24, 2015 09:18 PM
