RE: What would cause oil to drip out of my filter
Heres the diagnosis. The motor was just barely out of balance which caused the exhaust cam bolt on the driver side top start to back out. when it broke and shot through the valve cover the timing chain fell off, the valves went into neutral position and the pcv valve started sucking oil into the intakemanifold.
Ouch.Good luck with the fix
