trunk question
Old Mar 5, 2007 | 01:52 PM
geetee03's Avatar
geetee03
Default trunk question
hey guys yesterday i tried opening my trunk with my key fob and it did not pop open! i tried pushing the button in the glove compartment and nada. i had to open it the old fashioned way with the key. the doors lock and unlock with the buttons so the battery is not out. any ideas what the problem is?
Old Mar 5, 2007 | 02:19 PM
ShadowDrake's Avatar
ShadowDrake
Default RE: trunk question
Check fuses first, I'm not sure if it's the same fuse as the door locks. If the fuse is still fine, check the wiring for the little servo the actuates the lock release for the trunk... a connection probably came loose.
Old Mar 5, 2007 | 03:09 PM
ghstintheshell's Avatar
ghstintheshell
+1
Old Mar 7, 2007 | 02:42 AM
geetee03's Avatar
geetee03
bump bump bump bump bump bump bump
Old Mar 7, 2007 | 02:46 AM
ShadowDrake
ORIGINAL: geetee03
Why? I already answered this. At least say if the solution worked or not and say what you actually tried.
Old Mar 7, 2007 | 03:00 AM
97targa's Avatar
97targa
ORIGINAL: ShadowDrake
ORIGINAL: geetee03
Obviously it wasn't a good enough answer or not he answer he was hoping for.[:@] Here it goes....
You stand up with your toes pointed towards each other! Lean on your toes with weight and click your heels together while saying fix my trunk 3 times together.[sm=signs003.gif] That should fix the problem and make your life as easy as you hoped! [sm=laughat.gif]
Old Mar 7, 2007 | 03:02 AM
geetee03's Avatar
geetee03
i checked the wiring seemed to be fine, looked at fuses but i was not sure which was the right fuse.
very insightfull 97targa
Old Mar 7, 2007 | 03:03 AM
97targa's Avatar
97targa
ORIGINAL: geetee03
I know right???? c'mon pretty funny though!
Old Mar 7, 2007 | 03:07 AM
ZW99GT's Avatar
ZW99GT
Get out your manual and see if they truck popper thing has its own fuse.
Dokilar
15
Oct 16, 2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
treesloth
Sep 28, 2015 07:03 AM
