2nd gear grind
My tranny shifts fine into 1,3,4, and 5th, but when i shift fast into 2nd it grinds. I did just learn stick about a month ago but i do not think it is a driver fault...It only happens when i shift like really hard as if i were racing, which i am unable to do unless i leave in2nd from a roll.All other gears are fine...
Any ideas followed with prices to fix?
sounds like your synchros are fugged!! my car used to do the same thing except mine would only grind when i shifted into 3rd. it started out like yours then started grinding every time i shifted into 3rd....didnt matter if i was driving hard or not. i ended up having to take my car in and having almost $3k worth of tranny work done. they replaced all the synchros, 2nd gear, 3rd gear, and some other stuff. thank god for extended warranties....only cost me $100
that was the cost from the ford dealership. if i wouldnt have had my extended warranty then the best bet would have been to buy a whole new tranny for a lot less than $3k or even a used tranny off a wrecked stang!
