Special tool?
ORIGINAL: korn253
You dont time the heads, you time the cams. I think your talking about the cam positioning tool.
ORIGINAL: 96GT226410
The tool to time the heads.
They may be talking about this... Its used to compress the valve springs while the heads are still on the block... I had to buy and use this when I replaced my valve springs.... http://www.thetoolwarehouse.net/shop/OTC-7928.html
But if you take the heads off you can use a different cheaper valve compressor to take them off. Theres also a
Anderson Ford Motorsports sells a tool where you dont have to take the timing cover off to swap cams.... Here... http://www.andersonfordmotorsport.co...log/Page31.jpg Those are the only two tools I can think off... Check the manual im sure theres a part number and google it.
