[Deleted]
Why would you need a different intake...
It'll work fine. Dry shots are alittle more risky. I'm not up to date on wether you really need to tune the car for a small shot like a 75-100. Maybe I can learn something from this thread.
make absolutely sure you have a WOT switch with a wet kit, and an rpm switch would be nice so that you don't hit the juice till your rev's are up above 2500 rpm or so. A bottle pressure gauge is a must if you wanna run good times, and a bottle heater will help ensure your bottle pressure is consistant. A purge is nice to ensure you get a good hit of juice off the line without bogging
Everything is know about nitrous, md is 100% correct. I consider the WOT switch and something to monitor the rpms a saftey thing. If not for you, for your Mustang. Either way, those two should be part of your "required" list. The other stuff, well, they are pretty important two - but I would not install a nitrous system without the first two.
Take care,
Ceyko
Take care,
Ceyko
