drive shaft
Old Mar 15, 2007 | 02:15 AM
TimmyGt's Avatar
TimmyGt
Default drive shaft
So I ordered a new light weight drive shaft for my mustang.
do you think I will feel any difference with this new drive shaft over the older one?
Old Mar 15, 2007 | 02:23 AM
NORMAN99's Avatar
NORMAN99
Default RE: drive shaft
If it is the light Aluminium drive shaft you might feel a slight difference. I did.......
Old Mar 15, 2007 | 02:26 AM
TimmyGt's Avatar
TimmyGt
yeah, it is the ford racing aluminum one.
ORIGINAL: NORMAN99
Old Mar 15, 2007 | 02:40 AM
sleeping stallion's Avatar
sleeping stallion
what does doing this do to ur performance
Old Mar 15, 2007 | 02:44 AM
TimmyGt's Avatar
TimmyGt
ORIGINAL: sleeping stallion
here is the write up for what it does.
"By using a lighter weight driveshaft, you reduce its rotational mass while it is turning, freeing up horsepower, which translates to faster speeds and lower ETs. These lightweight aluminum driveshafts are just the ticket. They feature high-strength, .114 in. wall thickness, a 6061-RT62 aluminum seamless tube, and include 1330 high-performance U-joints. They weigh approximately half as much as your OEM steel shaft, but are twice as strong!"
Old Mar 15, 2007 | 02:46 AM
sleeping stallion
oh so does it really work or is it that u only feel it when u have a full bolt on or f/i car
Old Mar 15, 2007 | 03:04 AM
TimmyGt's Avatar
TimmyGt
well it is more for the loss of power from your crank to the ground. when you use lighter parts it get more of the hp to the wheels then the stock parts.
Old Mar 15, 2007 | 03:07 AM
cahtr6's Avatar
cahtr6
Less rotating mass weight means you reach rpm faster.
Old Mar 15, 2007 | 03:08 AM
NORMAN99's Avatar
NORMAN99
Take account what Jimmy said, Lighter is better!!!
Old Mar 15, 2007 | 03:10 AM
NORMAN99's Avatar
NORMAN99
Take that in account what Timmy said, lighter is better!!!!!
