Daiblo Predator Tuner...
Old Nov 8, 2004 | 05:09 PM
Master's Avatar
Master
Default Daiblo Predator Tuner...
just looking to get the most i can out this tuner.. does anyone know what the spark advance is on the programmed tune that way i know how much for i can alter it?
ALSO.. with my mods should i need to modify the WOT setting?
also the fan settings. what should i change in that section, IF ANY... im not sure.
one last thing... should i be altering the programmed tune or should i make whole new tune that way i tune from stock and not from an already programmed tune?
THX in advance
Old Nov 8, 2004 | 10:25 PM
Cedarkill's Avatar
Cedarkill
Default RE: Daiblo Predator Tuner...
By spark advance, do you mean stock ignition timing. Because I know the stock timing is 10 BTDC, if you're planning on advancing the timing, which is probably a good idea to tweak some extra power, I wouldn't exceed 13 or 14 degrees, esspecially considering your PI car has higher compression than my '96 non-PI GT. The more advanced the timing, and the high compression, there is a greater need for higher octane fuel. You'll get away advancing your timing a couple of degrees as long as you run 93 octane.
Old Nov 9, 2004 | 02:42 AM
ponygt's Avatar
ponygt
you should advance your timing for sure, nothing past 14 as stated. definantly improve the throttle response. whenever you add a mod, the tuner helps you to get the most out of it. its nice to have it, especially after you spend that much money on what looks to be a gameboy
Old Nov 9, 2004 | 03:21 AM
Master's Avatar
Master
ya i advanced the spark advance, but i feel there is alot more i can get out of this tuner cause there are WOT settings, and the fan settings, i need some one to help me out that has some good expierience with the predastor.
Old Nov 9, 2004 | 11:59 AM
BLUE04GT's Avatar
BLUE04GT
if you set your spark advance all the way, it will only get you to 12 degrees of timing. It is one downside to the predator. Change all the fan settings to get them on earlier.
Old Nov 9, 2004 | 12:30 PM
yellowstang98's Avatar
yellowstang98
whays better a diablo chip with a good burn, or a predator tuner? cuz the shop that i go to, its 120 bucks for the 1st burn and then free life time reburns
Old Nov 9, 2004 | 12:39 PM
Redline03GT's Avatar
Redline03GT
I'm buying the Hypertech - It allows me to run on 87 octane fuel whereas the Diablo Sport requires 91.
Old Nov 9, 2004 | 01:49 PM
yellowstang98
whats the big deal-why wouldnt run 91 anyway(i can tell a big diff when i run 87 and when i run 91)- i mean you pay 25k for a car but then you dont want to pay the 15 extra cent a gallon for gas. [sm=wakeup.gif]
Old Nov 10, 2004 | 12:02 AM
not stock 26's Avatar
not stock 26
much more potential from a diablo chip then a tuner. take it to a dyno have them burn one for you. yes its more money about 400 for one plus dyno time but again more potential
Old Nov 11, 2004 | 02:40 AM
neogenic83's Avatar
neogenic83
i had a hypertech and when i went to the dyno it ran really lean at some points 17:1 i wouldn't use it got a diablo tunner and love it everything is where it is supposed to be also the diablo tunner can be upgraded later down the road with the hypertech u are stuck with what they think is right
