Question
Ok kind of a crazy question but hopfully some of you are running close to the same setup and can answer it. Im running eibach prosports, Tekio adjustable front struts, Tubular k member, strange 10 way adjustable, sub frame connectors, 31 splines, 262 cams, 100 shot, and a stage 3 clutch w/ alum flywheel, on a 03 5 speed GT do you think that i can pull the front wheels or at least the left front on stickies????
Also i am installing L/T's do you need to use antisieze on the header bolts?
On pure slicks? maybe just a bit. the lowering springs just dont weight transfer nearly as well as other springs do.. they keep it planted just a bit to much.. they actualy making launching harder and raise your 60' times a bit.... if you were running some drag launch springs or even fox body 4cyl springs I think you would do it for sure. It wouldnt suprise me one way or the other.
I know im almost thinking of putting the stock and some fox body spring on it and pulling the Eibachs just so i can get a better launch. I love the way it sits though.
ORIGINAL: GT 281
Everyone here loves Emu.. [sm=lol.gif]
