Does 4V Block Work for 2V engine?
Old Mar 18, 2007 | 02:12 AM
4.6LPoppy's Avatar
4.6LPoppy
Default Does 4V Block Work for 2V engine?
Sometimes I think I know and then find out I don't . I trashed my 2V on the first run of the season. A family member has a block out of a Cobra. Can I use that block? I'll be putting new rods and pistons in but want his forged crank in the block. I'll also be putting back the 2V PI heads and Bullit intake. I think I can, but thought I would ask. Thanks.
Old Mar 18, 2007 | 04:09 PM
4.6LPoppy's Avatar
4.6LPoppy
Default RE: Does 4V Block Work for 2V engine?
Doesn't anyone know the answer to this question???
Old Mar 18, 2007 | 04:34 PM
viper104's Avatar
viper104
you shouldbe able to they are the same block.
na svt's Avatar
na svt
Yes, it will work. But you will need 4v pistons.
Old Mar 18, 2007 | 04:36 PM
na svt's Avatar
na svt
IT will work but the compression will be very high with the 4v pistons.
Old Mar 18, 2007 | 04:53 PM
oxfordgt's Avatar
oxfordgt
Yes it will work it is the same castings. All parts are interchangable between the 2v and 4v. What year is the block?
Old Mar 19, 2007 | 01:16 AM
4.6LPoppy's Avatar
4.6LPoppy
Thanks all. Yes, I found out by searching online also that the blocks are interchangeable for the most part. There are some minor differences and you can get some compression changes if you mix heads and blocks from different years. I'm just talking about using only the block and crank....no pistons. So, I'll use the Cobra block (aluminum) and forged crank, and put my 2V PI heads, Bullit intake, etc. on it. I did find out that most Windsors have 10mm bolts on the engine cover and Romeos have 8mm bolts. This is only important if you have a supercharger ( I do) with mounting plates utilizing these holes. Thanks again.
Old Mar 19, 2007 | 01:38 AM
BraMas's Avatar
BraMas
Remember you will need a new Flywheel if you go with the Cobra Crank. It's a 8 bolt and your 2V is a 6 bolt
Old Mar 19, 2007 | 02:12 AM
bransdaman78's Avatar
bransdaman78
I ♥ Acer
which year mustangs have the 6 bolt again?
Old Mar 19, 2007 | 02:14 AM
4.6LPoppy's Avatar
4.6LPoppy
ORIGINAL: BraMas
You're right. Forgot about that.
