How do gears work?
Old Mar 22, 2007 | 04:21 PM
Nitti00GT's Avatar
Nitti00GT
Default RE: How do gears work?
Wow, that actually did make sense. So that's what they mean by the gear is a mulitplier. So basically when I get my 4.10s my car will take off because it will be mulitipling the torque to a number higher then the weight of my car. Also stock Mustangs have 260hp lol.
Old Mar 22, 2007 | 04:26 PM
Nitti00GT's Avatar
Nitti00GT
I have a question? So when you start modding your car and lets say keep it N/A, would 4.10s multiply the torque too much causing you to not catch traction off the line? Now lets say you supercharge your car, would the 4.10s be worse then say 3.73s like everyone says?
Old Mar 22, 2007 | 04:37 PM
SuperNooblet's Avatar
SuperNooblet
they say that 4.10's and a s/c will hurt your tires like a sharp, heated blade to slightly heated butter. i plan on doing it though, will just take some phat rubber and the right suspension upgrades to keep those tires from resembling, well, I can't quite get a kid-friendly analogy for this one....sorry guys
anyway, 4.10s will burn too much rubber and rob you a few top speed mph's. 3.73's are a happy medium i gather.
04MustangGT's Avatar
04MustangGT
good question? anybody...
Old Mar 22, 2007 | 04:53 PM
BadSnake711's Avatar
BadSnake711
That chart looks wrong
Old Mar 22, 2007 | 05:07 PM
01GTCONVERTABLE's Avatar
01GTCONVERTABLE
Thanks for all the info, that makes sense! I told you I wasn't the smartest person, lol!
And I'm pretty sure those numbers are correct, here's where I got em from.
http://www.tchracing.com/tech/gearca...selectedgear=2
Old Mar 22, 2007 | 05:52 PM
runninmike's Avatar
runninmike
A good way to help understand it is to think of a mountain bike's gears. When you are using the big ring gear or sprocket, it is much easier to climb or take off initially and as you shift to higher gears (smaller spockets or gears) it goes faster. If you start off with a small ring or gear, it is slower to get going. Like 1 of the posts above, the torque is multiplied faster with a bigger, taller, higher gear or sprocket. Just like using different blocks and tackle to achieve lift.
Hope this helps some.
Best-MC
Old Mar 22, 2007 | 06:48 PM
01GTCONVERTABLE
Are thosenumberson my tablecorrect?
Old Mar 22, 2007 | 07:06 PM
Js 99 GT's Avatar
Js 99 GT
No
Old Mar 22, 2007 | 07:58 PM
01GTCONVERTABLE
Well,I used a MPH/RPM calc....how are they wrong??
