reverse light problem...
Old Nov 14, 2004 | 03:08 PM
Dan04COBRA's Avatar
Dan04COBRA
Default RE: reverse light problem...
Oh you don't have to rip your dash out. I believe the relay should be located near your e-brake, atleast it is in most cars.
Any loose wires will probably be located near your shifter...
Old Nov 14, 2004 | 03:12 PM
Master's Avatar
Master
you not talking about that set of wires running across the tranny you see when changing the shifter out ?
Old Nov 14, 2004 | 03:20 PM
Guest
Guest
Posts: n/a
ORIGINAL: Dan02GT
But it's a perfect excuse to get some stock tail lights and throw out those Altezza's. [8D]
Old Nov 14, 2004 | 06:27 PM
Casper98GT's Avatar
Casper98GT
I ♥ Acer
Maybe you messed up something when installing the new shifter. Have you had youre trans out for any reason, because youre reverse switch is on youre trans. I did a clutch in my car and the way the wires are set up on the switch.. well its a ****ty design. The prongs are so close together they touched when i put them back on and my reverse lights came on sometimes. Its not a very hard thing to fix. It can only be a few things.
Old Nov 15, 2004 | 03:48 AM
Master's Avatar
Master
no, no tranny work, all i did was install the Tri-ax shifter...
Old Nov 16, 2004 | 02:22 AM
jmcc1980's Avatar
jmcc1980
Fo Shizzle! Quite Ugly IMO.
Old Nov 16, 2004 | 02:24 AM
jmcc1980's Avatar
jmcc1980
Where are your cobra rims that you have listed in your list??? Those look like stockers to me...
Old Nov 16, 2004 | 10:42 AM
1{}D{}{V}{}DGT's Avatar
1{}D{}{V}{}DGT
Sounds like a loose wire,
thats what it seems like to me do u have indiglo gauges or anything ??
Old Nov 16, 2004 | 04:00 PM
Master's Avatar
Master
yes i have indiglo gauges... and yes i have cobra rims... i need to get a friend with a digital camera to take more pics cause i also dont have stock rear tires anymore
Old Nov 16, 2004 | 05:27 PM
1{}D{}{V}{}DGT
could be ur gauges just a thought or the lose wire when u get on it it moves and hits another wire i dont know
