subframe installation
Old Mar 29, 2007 | 11:18 PM
1BadSonicBlue02GT's Avatar
1BadSonicBlue02GT
Default subframe installation
Ok i got a set of sub frame connectors, full length, and i would like to know if i can install them myself. i have a MIG welder which is what it calls for but ppl have said i need to make sure my frame is straight before hand. so will i be able to do this or should i have someone do it. all the ppl have quoted like 300$ plus. what should i do?
Old Mar 29, 2007 | 11:26 PM
JJ03MustangGT's Avatar
JJ03MustangGT
Default RE: subframe installation
it aint hard, just get a set of exhaust stands to hold em up while your welding. its a pretty basic mod.
Old Mar 29, 2007 | 11:35 PM
oxfordgt's Avatar
oxfordgt
You have to have your car on its suspension (sitting on the tires) inorder to weld on subframes. Most places will charge around $150 or you can buy 2 sets of ramps. Drive up on the front and use a jack and raise the rear and slide the ramps under the rear tires.
Old Mar 29, 2007 | 11:36 PM
1BadSonicBlue02GT
but will i have to make sure the frame is straight cuz i keep hearing that if it isnt straight and i weld them on there then it will always be crooked
Old Mar 29, 2007 | 11:38 PM
JJ03MustangGT
ORIGINAL: oxfordgt
yea i forgot that part....my bad
Old Mar 29, 2007 | 11:54 PM
1BadSonicBlue02GT
ORIGINAL: 1BadSonicBlue02GT
Is this correct? If so how do i ensure that it is straightand not crooked?
Old Mar 29, 2007 | 11:56 PM
oxfordgt's Avatar
oxfordgt
Yes you do that by doing what I posted.
cahtr6's Avatar
cahtr6
I was watching a muscle car episode and they said it is better to have the car on jack stands on all 4 corners to take the sag out of the unibody.
Old Mar 30, 2007 | 12:06 AM
1BadSonicBlue02GT
the instructions say a drive on lift or a set of ramps for the front and jack stands for the rear
mtgldr
Feb 3, 2024 09:00 PM
Sep 10, 2015 08:39 PM
Sep 8, 2015 11:50 AM
Sep 1, 2015 08:16 PM
