Drag suspenion?
Old Apr 6, 2007 | 10:26 PM
MustangMike8705's Avatar
MustangMike8705
Default Drag suspenion?
I have been thinking about getting Lakewood's 70/30 drag struts, 50/50 rear shocks and Eibach drag launch springs. I was j/w if anyone has them andhow streetable they are etc. Im going to be putting themon my daily driver butI have a serious traction problems on the weekend whenI race, Im getting desperate, lol.Itsfor a 02 Mustang GT. Any info would be great.
Thanks for the help.
Old Apr 6, 2007 | 10:28 PM
MustangMike8705
Default RE: Drag suspenion?
Drag Suspension*
Old Apr 6, 2007 | 10:50 PM
sstang's Avatar
sstang
I want the eibach springs as well. As for the shocks and struts, that would be a good set up, although adjustable would be better so you can adjust it for optimum performance at the track while still having a good ride quality. Look into strange adjustables.
Old Apr 6, 2007 | 11:28 PM
JayC's Avatar
JayC
The only problem I know with the Eibach springs is the ride height is about the same (4X4) as stock. Here's what I drive almost every day that gives me 1.5 60's and a 1.5" drop.
Fox-body 4cyl springs(NAPA #270-3060) up front w/ Lakewood 90/10 struts
Fox-body V8 rear springs (cut 1 turn) w/ Monroe Sensi-trac shocks
Airbag in RR spring
No front swaybar
UPR sub-frame connectors
Steeda 4600 Lower Control Arms
D&D adjustable uppers
Torque boxes welded
No quad shocks
and a pic....
Old Apr 6, 2007 | 11:49 PM
oxfordgt's Avatar
oxfordgt
Those shocks in the rear would suck on the road. spend a little extra and get adjustable shocks.
My set up:
FRONT
QA1 K member
QA1 A arms
QA1 adjustable struts
QA1 coilover kit
hypercoil 175# springs
4 bolt CC plates
bump steer
REAR
Steeda HD upper and lower control arms
cut stock springs
QA1 adjustable shocks
quad shocks removed
full length subframes
welded torque boxes and axels.
Old Apr 6, 2007 | 11:58 PM
JayC's Avatar
JayC
ORIGINAL: oxfordgt
My set up:
FRONT
QA1 K member
QA1 A arms
QA1 coilover kit
4 bolt CC plates
bump steer
REAR
cut stock springs
quad shocks removed
Sorry but they work quite well with a stock Fox spring rate. Of course adjustables would be better, but the Stranges are unreliable and noisy and the QA1's are known to leak in daily driving applications. You have probably 3 times the money in your set-up that I bet doesn't out-perform mine. What are your 60's BTW?[8D]
01GT4.6's Avatar
01GT4.6
ORIGINAL: JayC
Airbag in RR spring
No front swaybar
Torque boxes welded
No quad shocks
and a pic....
stfu old man, like you know what you are talking about!
j/k :luv:
Old Apr 7, 2007 | 12:00 AM
01GT4.6's Avatar
01GT4.6
I have the same front setup as JayC but I went stiff for the rear so I don't use an air bag, my rear setup is FRPP "C" springs (dead coil cut) and Bullitt Shocks (Tokico). I ran low 1.6 60' on stock control arms.
Old Apr 7, 2007 | 12:01 AM
RC5522's Avatar
RC5522
Have you tried out some traction action bars by lakewood ?
I had mass mods on my 95 all bolt ons .B- cam , aftermarket intake and heads. I had some subframe connectors on , good tires , and traction bars.My car would lift nice ( not front wheel lift) But Im saying it would hook up.
Old Apr 7, 2007 | 12:02 AM
oxfordgt's Avatar
oxfordgt
ORIGINAL: JayC
ORIGINAL: oxfordgt
My set up:
FRONT
QA1 K member
QA1 A arms
QA1 coilover kit
4 bolt CC plates
bump steer
REAR
cut stock springs
quad shocks removed
After I installed the setup and before I blew my engine i was pulling 1.6 60' with my buddys slicks and 1.9 on street tires.
