Can I use my stock cam gears and bolts when installing VT stage 1 cams?
Can I use my stock cam gears and bolts when installing stage 1 VT cams? Do I need anything for installing just the cams and no springs?
RE: Can I use my stock cam gears and bolts when installing VT stage 1 cams?
yes
you want to keep your stock cams while installing VT stage 1 cams? :eek:
he said cam gears
It depends on what model 01 you have. Have you looked to make sure you have bolt on gears.
No, how can I tell with out pulling apart the motor? What would I have to do/buy diferently between the two setups?
If you have pressed on gears then you will have to buy gears and bolts. They are cheap and can get them from SHM.
If you have 13 bolts in your valve covers then you have pressed on gears. If you have 11 then you have bolt on gears and can reuse them. |
ohhhhh.. i mis read. i thought he said cams gears and boltons and just forget puncuation. my bad[&:]
