HELP!!
Old Apr 15, 2007 | 06:36 PM
03machyellow's Avatar
03machyellow
Default HELP!!
i have an 03 mach 1 and need a new clutch what should i get? i drive it hard so keep that in mind considering not even 30k and i have to replaced it.
Old Apr 15, 2007 | 06:44 PM
oxfordgt's Avatar
oxfordgt
Default RE: HELP!!
Id say get a stock replacement untill you learn to drive a stick.
Old Apr 15, 2007 | 06:46 PM
JJ03MustangGT's Avatar
JJ03MustangGT
Default RE: HELP!!
depending on your future plans for the car id say stage 1 clutch would do you fine. since your basically stock, the clutch should be just fine
Old Apr 15, 2007 | 06:54 PM
04BlueGT's Avatar
04BlueGT
Default RE: HELP!!
I personally like the CenterForce DF clutches. Less slip than stock by far without making it jerk your fillings loose on every shift.
Old Apr 15, 2007 | 07:44 PM
xxkazp3rxx's Avatar
xxkazp3rxx
Default RE: HELP!!
If you plan on stock/close to stock... keep a stock clutch - you really won't benefit on the other ones... if you plan on really modding your car then it's a different story...
Old Apr 15, 2007 | 10:19 PM
03machyellow
Default RE: HELP!!
i have done a few things already and more are coming.
Old Apr 15, 2007 | 10:23 PM
theorgnlimprtkillr's Avatar
theorgnlimprtkillr
Default RE: HELP!!
ORIGINAL: 03machyellow
get a centerforce clutch, they're a little pricey but you have a lifetime guarantee on them
Old Apr 16, 2007 | 01:19 AM
Sniper6677's Avatar
Sniper6677
Default RE: HELP!!
ORIGINAL: theorgnlimprtkillr
Im pretty sure thats only if you have the flywheel resurfaced as well correct?
