adjusting timing?
Old Dec 2, 2004 | 12:32 PM
yellowstang98's Avatar
yellowstang98
Default adjusting timing?
is it reccomended to adjust the timing on a 98 to 14 too??? and if so can u do that with a diablo chip or do i have to get a timing adjuster?
Old Dec 2, 2004 | 12:34 PM
mdvaldosta's Avatar
mdvaldosta
I ♥ Acer
Default RE: adjusting timing?
you can do it with either, and I hear 15* is ok usually but I'd do 14
Old Dec 2, 2004 | 12:36 PM
jdaniel's Avatar
jdaniel
I ♥ Acer
On a '98 you can adjust it to 14...MAYBE 15 and still be safe. The compression ratio is 9.0:1 so it isnt far off what the 2001+ GT's run which is 9.4:1
Old Dec 2, 2004 | 12:39 PM
yellowstang98
then ill be running up there with you guys....
Old Dec 2, 2004 | 04:05 PM
Cedarkill's Avatar
Cedarkill
With a steeda timing adjuster, steeda says you can run safely 4-6 degrees advanced on a 96-98 (non-PI) 4.6. I'm running 93 octane with my timing advanced to 16 degrees problem free. Of course I started at about 13 degrees and slowly worked my way up to 16 listening and driving it between every change. I stopped at 16 because that's the max recommended, it didn't start pinging or anything like that, but I'm sure it will start if you exceed 16....
Old Dec 3, 2004 | 02:19 AM
stonemonk9's Avatar
stonemonk9
I heard those diablo tuners are only for 99+, so I think ud have to stick with the steeda or upr or somthing.
Old Dec 3, 2004 | 02:27 AM
mdvaldosta's Avatar
mdvaldosta
I ♥ Acer
ORIGINAL: Cedarkill
yea I suppose thats right since the non-pi's had lower compression
Old Dec 3, 2004 | 05:04 AM
StangTangGT's Avatar
StangTangGT
if its product number U7146 then the diablo works on 98's too.
Pyrate Dave
Sep 10, 2015 07:30 PM
DoctorScary
Sep 9, 2015 07:53 AM
RWHEELS
Sep 5, 2015 03:42 PM
Luke9222
Sep 4, 2015 06:46 AM
Sep 1, 2015 08:16 PM
