Steeda Timing Adjuster
I think I read in Steeda's catalog that it does work with the OEM crank pulley. What it does is let you adjust the base, mechanical timing of the ignition--the part the PCM doesn't know about and assumes to be 10° BTDC (IIRC). [/align][/align]It's only needed and useful if your engine is a long way away from stock, to the point that engine life is a very far distant consideration as compared to maximising power output...[/align][/align]
http://www.musclemustangfastfords.co...5mmff_boltons/
just found this sight. 10hp and 25lb ftwith steeda underdrives and steeda timing adjuster on a stock mustang. I know my car is npi but i dont think that would affect my numbers with this mod that much. Anyone use the timing adjuster?
i have one on my car couldnt realy tell a difference but i did have to set it back to 0 when i installed the diablo tuner, so it just looks fancy now, i suggest getting the tuner if you want to play with your timing plus it will come in a lot more handy later down the road if you do more to it
Sep 2, 2015 08:40 PM
Sep 1, 2015 08:16 PM
