RE: Having a problem.
Check your fuel pressure . I had the same problem with mine . it might be a weak pump . mine still worked but would bog and pop upon accelleration or under a load . be careful because running lean causes detonation and detonation causes you to have to get a new motor . Good luck
+1 for the fuel filteror pump or both.
Wouldn't hurt to dump some fuel injector / fuel system cleaner in the tank while your at it.
ORIGINAL: SpartanStang ORIGINAL: LX90 It boggs whenever it hits WOT, if I gradually excellerate, it runs fine. It idles fine, but if it I floor it (hit WOT) It boggs and drags till I let off. |
ORIGINAL: OzzDOA +1 for the fuel filteror pump or both. |
