Technical Ponies !!!
Old Apr 29, 2007 | 12:55 PM
xander0561's Avatar
xander0561
Default Technical Ponies !!!
So I went to advanced auto parts yesturday and had my car read. The "check engine" light has been on for some time, after I did my PI swap []. The code came upas follows "P1443" it says , Manufacturer Control Auxiliary emission Controls" What the heck is that? [&:] haha Any Ideas.
Old Apr 29, 2007 | 01:03 PM
jpmustanggt's Avatar
jpmustanggt
Default RE: Technical Ponies !!!
Do you have cats? Could be something to do with that.
Old Apr 29, 2007 | 01:05 PM
IROLLSALEEN's Avatar
IROLLSALEEN
I'll take a crack at it, the code means "Evaporative Emission Control System- Vacuum system- Purge control solenoid or purge control valve fault.
Its a vac leak of egr or something of that nature. Take a good GOOOOOOOD look at all the **** on the top of the motor.
Hope I could help.
Old Apr 29, 2007 | 01:08 PM
IROLLSALEEN
that code has nothing to do with cats
Old Apr 29, 2007 | 01:12 PM
xander0561's Avatar
xander0561
DING DING DING!!!! youare correct its an evap sensor. I was looking on-line and thats what they say it is. So I'm going under the hood with a flash light too see what I can see, It also could be a bad gas cap or charcole filter.I hope I can fix it.
Old Apr 29, 2007 | 01:14 PM
IROLLSALEEN
good luck man
96GT226410's Avatar
96GT226410
CSMG Moderator
Open your hood. There are two sensors by the firewall on the passenger side. You'll see them. They are EVAP codes and are common of the first gen. 4.6 in Fords. I have the same code on my car, too. Ha ha... Get the two sensors from Ford. They're $30, I think. If you need more help, I can take a picture of mine tomorrow. Good luck...
Old Apr 29, 2007 | 01:30 PM
xander0561's Avatar
xander0561
Thanks guys And yes I would love some pics, I think I have an Idea of what they are [&:]
Old Apr 29, 2007 | 06:25 PM
chrissilver3975's Avatar
chrissilver3975
I had the same code... I replaced the purge valve and now the code is back.. not sure what it is now.. guess ill check all the hoses and make sure nothing is loose.
baddog671
Jul 26, 2016 01:20 PM
Thunderball
15
Nov 22, 2015 11:49 PM
Florida Regional Chapter
Sep 30, 2015 08:04 PM
Steve@CJPP
CJ Pony Parts
Sep 24, 2015 02:51 PM
GTJIM
Sep 23, 2015 09:59 AM
